Re: Hotter spark plug
Posted by Janicholson on May 02, 2013 at 14:45:15 from (74.60.94.18):
In Reply to: Re: Hotter spark plug posted by Bob Reineke on May 02, 2013 at 13:32:52:
I have substantial experience with single plug fowling. It has always been an issue with oil. Stuck rings and over oiling of the walls, or worn ring lands pumping oil up top where it fowls a plug, or moderately worn valve guides. The guides are nearly cost free to fix with umbrella seals under the retainers. and that should be task #1.
The other issues are rebuild time.
A warm engine that has been leaned (as you indicated earlier)Will vaporize fuel readily. Oil has both ash, and metallic compounds it it that are nearly invisible but conduct electricity down the center electrode fouling the plug. Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
