Re: Water Jacket Cover
Posted by D Slater on May 02, 2013 at 19:44:40 from (184.14.173.214):
In Reply to: Water Jacket Cover posted by Bud Kaiser on May 02, 2013 at 18:30:29:
450 should have come with flat washers on the bolts. Although they are close to the same size as a lock washer. Sized between lock and a SAE flat if I remember correct.
Never liked to use silicon much. But found it seals the covers better than a gasket with sealer for me. Just a small bead without a gasket seems to work without problems. Use brake cleaner for last cleaning before use. But I do let it set for 48 hours before putting coolant in.
