Re: Should I use Hy-Tran?
Posted by sflem849 on May 03, 2013 at 09:34:03 from (69.197.84.39):
In Reply to: Should I use Hy-Tran? posted by caseman-d on May 03, 2013 at 08:39:44:
I agree, they are not trying to sabatoge your tractor. They have updated their recommendation.
So does hytran absolutely never have anything that will hurt your copper/brass like GL-5?
