Re: Super A - 140 Steering Bushing Kit PROBLEMS
Posted by Janicholson on May 03, 2013 at 17:24:08 from (74.60.94.18):
In Reply to: Re: Super A - 140 Steering Bushing Kit PROBLEMS posted by RTR on May 03, 2013 at 09:43:32:
YThe bushing should have a .001 to .0008" interference fit into the housing. If machined to that diameter on the OD, it will not "shrink" very much on the inside when pressed in. THe inside might need to be reamed to the worn shaft diameter for perfection. (the shaft might need to be ground to allow the smallest diameter to be the only diameter and fit to the bushing). Some "kits" are intentionally designed for Pro fitting of components. Best of luck, it is doable.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
