Re: oil in water after rebuild
Posted by rustred on May 03, 2013 at 21:31:11 from (74.214.152.80):
In Reply to: oil in water after rebuild posted by IH584D206 on May 03, 2013 at 20:38:51:
well hard to say without really knowing all the details. like was the head magnafluxed and block checked out. but i have never heard of waiting overnight to retorque a head. put the engine together then start up and run to operating temp for an hr. or so then retorque while warm and reset valves.
i have also seen head gaskets put on dry leak to the outside and then once started and up to temp the leak is sealed. if leaking on out side it just as well could be leaking inside. have you looked in rad when tractor was running? also may need to pull the pan an watch for the leak. i never add the coolant till i am ready to start an engine after o/h.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
