what you need is a ballast resistor. I know nothing about a chrysler resistor but it may only function properly in conjunction with its other components. If there is a terminal on your starter solenoid that is 12v ONLY when the starter is engaged connect it to the coil side of the ballast for a hotter cranking spark.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
