If its a 12 volt system and has a true 12 volt coil YOU DO NOT USE A BALLAST OR THE SPARK WILL BE VERY WEAK.........(Toss the ballast)
A true 12 volt coil may be labeled "12 volt" orrrrrrrrrrrrr "12 volt NOT for use with ballast resistor" or "12 volt no ballast required"
A coil labeled "6 volts" or "12 volts for use with Ballast resistor" is in reality a 6 volt coil AND DOES NEED A BALLAST ON A 12 VOLT SYSTEM or it will overheat plus burn points quickly
Contrary to Billy Bob and Bubbas belief those coils DO NOTTTT I REPEAT NOTTTTTTTT HAVE A STAND ALONE DISCRETE BALLAST RESISTOR TUCKED AWAY SOMEWHERE INSIDE THE CAN.
Many typical old tractor 12 volt coils will have a LV primary resistance (measured between + and - terminals) of around 2.5 to under 4 ohms
If you have a 12 volt tractor and a 12 volt coil DO NOT USE A BALLAST OR THE SPARKS VERY WEAK
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
