Re: Hotter spark plug
Posted by 300 dave on May 05, 2013 at 06:24:11 from (50.48.63.138):
In Reply to: Hotter spark plug posted by Bob Reineke on May 02, 2013 at 10:46:45:
hi, my 2 cents- belated- you might want to check the rockers/valves etc,just quickly. make sure they are all working:correctly. I went through a similar hot plug quest on a 350U backhoe. It fouled #2, then other 3 within 2-3 hours. Turns out the woodruf key on the camshaft gear wallered out, and this also banged out the cam lobe,which wore a huge groove in the rocker arm shaft and bent the push rods. All this and she ran like a beast.
Dropped oil pan to check rod knock and decided to do complete overhaul. Then found all the other stuff.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
