Posted by El Toro on May 05, 2013 at 06:28:24 from (108.3.218.181):
In Reply to: farmall 230 posted by stoff230 on May 05, 2013 at 06:01:29:
Your engine is starving for fuel. Check the fuel flow from the tank to the carburetor. If there's a full stream of gas from the tank remove the tube fitting where your gas line connects. There may be a screen behind that tube fitting that has crud in it blocking your fuel to the carburetor. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
