Re: 656-666 sheet metal
Posted by John A. on May 05, 2013 at 12:43:18 from (64.128.16.238):
In Reply to: 656-666 sheet metal posted by Fourever Red on May 04, 2013 at 11:18:17:
F.Red, IMO a 656 has more in common with a 706 than a 66 series tractor I just aquired a 1964, 706 w/ a D-282. when setting side by side,, My 1966 656 LP has more in common with it than one might think!front end, casting holes grill, Op Deck, Seat assembly, Hydrologlic levers to start with. Hope this helps.
Later,
John A
