b414 fuel pump
Posted by rosedale123 on May 05, 2013 at 14:22:51 from (108.224.113.216):
I hate to keep bothering , but I am 'inching" to a conclusion.
I took the fuel pressure regualtor out of the fuel line and the the fuel just pours out of the carb ( an I mean pours !). I have also conclude the regulator does not work - it does not alow fuel to the carb and the adjustment does not work.
So, here is my question... I don't think the tractor is suppose to have a regulator so I think it has been added. Is it possible the fuel pump has been changed ( and the wrong one put on) an the person had to put a regulator to try and solve the over presssure issue?
If you were me would you change the fuel pump ( getting a stock one, assuming the one on is wrong) negating the need for the regualtor of get a regulator and attempt to reduce the pressure.
Thanks again for all your help.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
