Re: 300 Not Charging
Posted by Janicholson on May 05, 2013 at 18:22:30 from (74.60.94.18):
In Reply to: 300 Not Charging posted by VA Gasman on May 05, 2013 at 18:08:32:
Tap on the gauge when running. If it was running in the picture, the gauge should have indicated a discharge of about 2 to 3 amps (assuming it was not charging)
Check battery voltage when running at about 2/3 throttle. it should be 14.2 volts or so. If it is, the alt is charging, and the gauge is stuck. If it is not charging, (voltage at 12.4 to 12.6) then tell us which alternator it has so we can assist correctly. Jim
