Posted by Jim Becker on May 05, 2013 at 20:32:16 from (173.74.120.222):
In Reply to: Chydraulics posted by 292 Ralph on May 05, 2013 at 17:11:20:
Will you need to use the Touch-Control at the same time? If not, you can tap into the pressure plug on the rear of the Touch-Control manifold (the test port). Use that line for input to the remote valve. Hook the return from the remote valve in place of the Touch-Control filler plug. Use an open center valve.
Then run one of your TC rockshafts to the rear. Use a chain or solid bar to block the rockshaft in that position. Then push the control lever fully forward. The remote valve will work that way.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
