Re: Hey RustyFarmall!
Posted by rustyfarmall on May 06, 2013 at 08:04:33 from (216.248.71.226):
In Reply to: Hey RustyFarmall! posted by IAtractorKid on May 05, 2013 at 21:24:37:
Use a can of aerosol carb cleaner. NOT brake cleaner. Stick the nozzle into every orifice, and passage you can find on that carb and spray until it comes through somewhere else, and then stick the nozzle into where the spray came out and spray again. Pay special attention to the brass jet down in the bottom where the load screw fits. There is an area in behind there that SOMETIMES fills up with crud and is very difficult to remove.
When you think you have it clean, blow compressed air into each and every hole there is. If the carb IS clean, the compressed air WILL exit through another hole somewhere. If it doesn't, you are not yet done with cleaning.
Where abouts in Iowa are you?
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
