Re: 47 Farmall H, gear oil leaking after gear oil change
Posted by Zimbo711 on May 06, 2013 at 19:25:16 from (98.209.244.140):
In Reply to: 47 Farmall H, gear oil leaking after gear oil change posted by neblinc on April 26, 2013 at 15:02:53:
Hello Randy, I used those ready rod system to lower that belly pump it worked great. I proceeded to take off that spider , got the nuts all off , one bolt came right out. The other bolts seem to be stuck,i can not turn,i tried pounding a bit but nothing. Any suggestions? Thanks Bruce
