Re: Super C PTO slipping?
Posted by DeltaRed on May 06, 2013 at 19:57:54 from (97.118.25.134):
In Reply to: Re: Super C PTO slipping? posted by Jeyster on May 06, 2013 at 19:20:21:
If the clutch is not slipping,then the pto engagement 'dogs' are worn out.dismantle the thuing and have a look.Are you SURE the clutch is not slipping?test it.Put in low gear and hook it to a HEAVY load.It should kill the engine before the clutch slips.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
