Posted by Bill in NJ on May 07, 2013 at 06:55:15 from (68.34.248.57):
In Reply to: Gas in oil pan posted by Ihcrazy1 on May 07, 2013 at 05:01:52:
First let me say, I'm not familiar with the engine on this model tractor. Now, having said that, the first thing that jumped into my head when you said you had gas in the oil pan is, fuel pump. If this engine has a mechanical fuel pump and is mounted to the side of the engine, gas could be going through the diaphragm and flowing into the oil pan. JMO.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
