Posted by D Slater on May 07, 2013 at 07:31:55 from (184.14.173.214):
In Reply to: Gas in oil pan posted by Ihcrazy1 on May 07, 2013 at 05:01:52:
Could make sure the drain in the bottom of the bowl is not stopped up. Also shut the fuel off and remove the carburetor bowl drain plug over night with a catch pan under it to check for leak through the shut off. Are you pulling the tractor to start it after flooding? If its passing the rings running you should have a lot of black smoke. How long does it take to notice the gas in the oil? With the gas shut off when not running. Fastest way I know for gas to pass the rings and get to the pan is by pulling a bad flooded tractor with a lot of fuel build up in the intake pipe and carburetor after a failed start up with the fuel turned on.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
