Steering Housing Leak on a C
Posted by jeffred on May 07, 2013 at 15:39:00 from (208.126.231.218):
I just replaced the oil seal that is in the steering worm wheel shaft on a C. I also put a couple new gaskets on around the worm wheel shaft housing. I put the bolster back on and filled up the steering housing with oil, and then let the tractor sit overnight before I put the wheels back on. I went out this afternoon and noticed some oil leaking from the area I was working on. It almost looks to me like it is leaking out of one of the four bolts that holds that worm wheel assembly in place (I triple checked that everything was screwed in tight).
Does anybody have any ideas/suggestions on what might be causing this and how to remedy?
