Re: C301 Head Might Be A Crispy Critter....
Posted by Janicholson on May 07, 2013 at 16:53:52 from (74.60.94.18):
In Reply to: Re: C301 Head Might Be A Crispy Critter.... posted by Absent Minded Farmer on May 07, 2013 at 06:31:09:
I do not see a problem that machining won't fix. The process should just take out the recessed areas around each port. It does not need to flatten the chipped bolt hole it is irrelevant as it is not a sealing surface. The manifold will likely need to be replaced, but you know that.
A reputable machine shop can make it very usable.
Doing a valve job on it won't hurt. Stay with low ash oil from IH or others. Jim
