Posted by GordoSD on May 07, 2013 at 19:07:49 from (216.106.255.157):
In Reply to: Gas in oil pan posted by Ihcrazy1 on May 07, 2013 at 05:01:52:
Do you mead disconnect the fuel line from the carb? If that is the case then you have a carb that the float is not set properly or is stuck open. Have you checked or rebuilt the needle valve and float on that carb recently? How much gunk accumulates in your sediment bowl? Is it time for a gas tank cleaning? It's no good to have a nice clean rebuilt carb on there with really dirty fuel going into it.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
