Re: Farmall Super A hydraulic block safety valve stuck
Posted by Lester Reeves on May 07, 2013 at 19:15:53 from (50.96.209.209):
In Reply to: Farmall Super A hydraulic block safety valve stuck posted by Scott A Johnson on March 25, 2013 at 09:30:20:
Not sure which version you have. Just went through my Super A with new seals and such and found that the safety valve was missing piston. Made one from 1/4 bolt and working ok. It sounds like you have spring, sleeve and piston. If so the sleeve with 1/8" hole needs to be removed. You will find large hole into block with a piston about 7/8" long. Try blowing out sleeve or with tool that spreads out against inside sleeve and twist. Sleeve binding is problem. Les
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
