Re: Cub clutch bounces/chatters at the point of pressing
Posted by mkirsch on May 08, 2013 at 05:32:31 from (216.43.0.134):
In Reply to: Cub clutch bounces/chatters at the point of pressing posted by lekander883 on May 08, 2013 at 00:46:15:
Compared to the value of the tractor, paying someone to split it and replace the throwout bearing is going to seem like a major soaking. It's not a $50 job.
It sounds like yours only chatters when you "ride" the clutch, that is, resting your foot lightly on the pedal. Don't do that, and it won't chatter.
There is absolutely no point to pushing the pedal that lightly. It is not a valid diagnostic, and has no mechanical purpose other than wearing out the throwout bearing and the pressure plate fingers.
