Posted by D Slater on May 08, 2013 at 07:07:28 from (184.14.173.214):
In Reply to: Re: M oil pickup posted by billy boy2 on May 07, 2013 at 18:57:12:
If you look at how the right side of the oil pan bulges out in a section. That's where the oil pump body comes down from the block and part of the oil pickup ends up above the drain hole. Cotter pin keeps the oil pickup tube in the pump body. Tube will rotate up and down in the body and also slide in and out just a little. Will also wiggle a little. Tube has stops for total drop and raise. Once in a while but not often the stops may get bent or damaged.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
