IH C
Posted by George Marsh on May 08, 2013 at 13:35:24 from (50.104.198.127):
My 1950 IH C has started perfectly for years. Used it 3 hours to mow grass. Loaded it on trailer to bring home. Gassed up on way home. Go to unload it and no fire. Thought I may have gotten bad gas. Checked, had good spark. Checked spark plug, it was dry and gray. Removed plug from bottom of carb, had gas. Took compressed air, cleaned off the only adjusting screw on carb, removed screw, blew out jet without taking carb off engine. Put adj. screw back in, plug on bottom of carb and now it works just like before. The gas from carb didn't have water or dirt in it. Something in the carb blocked the jet. Sediment bowl had nothing in it either. Tank has no rust. Go figure.
George
  • Re: IH C Lmack 09:32:48 05/09/13 (0)
  • Re: IH C wayne in mn 06:15:23 05/09/13 (0)
  • Re: IH C old 15:04:34 05/08/13 (10)
    • Re: IH C gene bender 04:08:59 05/09/13 (5)
      • Re: IH C old 08:16:18 05/09/13 (3)
        • Re: IH C gene bender 03:35:17 05/10/13 (2)
      • Re: IH C George Marsh 05:28:01 05/09/13 (0)
    • Re: IH C George Marsh 16:54:20 05/08/13 (3)
      • Re: IH C old 08:18:32 05/09/13 (2)
        • Re: IH C George Marsh 10:06:04 05/09/13 (1)
          • Re: IH C gene bender 12:17:58 05/10/13 (0)
