Re: H oilpan petcock
Posted by FBH44 on May 08, 2013 at 18:35:32 from (64.85.215.53):
In Reply to: H oilpan petcock posted by Robert Jasa on May 08, 2013 at 17:46:38:
I put a dip-stick in my "H", I drilled a hole in the boss sticking out of the block above this area, carefully drilled a 1/8" hole for an inch, then a 3/16" for a while, then back to a 1/8" further down, and actually did not break off a bit. Had to drill through about 2 3/4" of cast iron. Put in a threaded nipple, and a Ford dipstick. Works great. If you do ths, pull the oil pan, to see where you"re drilling, becuase your dipstick will miss the crank by maybe 3/4". You"ll need to clean all the shavings out too.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
