Re: farmall M brakes
Posted by wayne in mn on May 09, 2013 at 06:05:55 from (71.8.147.153):
In Reply to: farmall M brakes posted by ohiojim on May 09, 2013 at 05:26:52:
After 70 years the drums are likely worn quite a bit. Measure the diameter & compare with new specs. Service manual should have a measurement for you.
