Re: farmall M brakes
Posted by FBH44 on May 09, 2013 at 09:24:44 from (64.85.215.88):
In Reply to: farmall M brakes posted by ohiojim on May 09, 2013 at 05:26:52:
Maybe I shouldn"t speak here, and I really don"t know, but if it"s like an "H" the first thing is to loosen the lock-nut on the bottom positioning screw, turn the screw up til the band contacts the drum, then loosen it a half-turn or so, and tigthten the locknut. THEN the band is positioned to be tigthtened.
Other thing is that the drum might have been so worn and scored [like mine is] that somebody turned it down, and removed 1/8" or 1/4" metal, and you might not be able to tighten it.
