Re: farmall M brakes
Posted by CharlieU on May 09, 2013 at 10:24:43 from (216.188.209.61):
In Reply to: farmall M brakes posted by ohiojim on May 09, 2013 at 05:26:52:
When I have ran into this same type of problem I have discovered that the pins that hold the brake band to the cam were wore down in size. I took a piece of round stock and cut new pins, It fixed the problem of running out of adjustment more than once for me. If you do not have any round stock you can use a bolt, cut the head and also the threads off. Let me know it that fixes your problem. Charlie
