Re: H oilpan petcock
Posted by rustyfarmall on May 10, 2013 at 06:55:40 from (216.248.71.226):
In Reply to: H oilpan petcock posted by Robert Jasa on May 08, 2013 at 17:46:38:
Previous experience indicates that you should drain the oil first, maybe even remove the pan from the tractor, and then use a torch to heat the area around the petcock, let it cool, and then use the pipe wrench. That petcock has been in there for a L-O-N-G time. It will not come out easily.
