Posted by rustyfarmall on May 10, 2013 at 10:53:00 from (216.248.71.226):
In Reply to: Gas in oil pan posted by caseman-d on May 10, 2013 at 08:31:51:
It is true the carburetor is gravity fed. It is also true that if the float valve is malfunctioning, the carburetor will flood, and yes, the excess gasoline will exit at the intake, but if there is a good, tight connection between the carb and air intake hose, the gasoline will proceed to fill up the intake pipe, but only to a point where it will then be as high in the carburetor as it is in the intake, and then the excess gasoline WILL exit through the governor tube and go directly into the oil pan. The laws of physics do apply here.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
