Posted by Paul from MI on May 11, 2013 at 04:37:22 from (204.106.248.120):
In Reply to: Gas tank clean our posted by Harrison58 on May 10, 2013 at 21:37:33:
I have never had much luck with anything I tried. I have taken them to a radiator shop, had them clean and line the tank with plastic--then no more problems!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
