Re: Super C Sleeve needed
Posted by equeen on May 11, 2013 at 08:18:16 from (209.102.248.236):
In Reply to: Re: Super C Sleeve needed posted by gene bender on May 11, 2013 at 07:33:55:
Someone has stated that Zollner made these for IH.
The pistons are marked IH 4079 with a Z on one side. IH part number 374294 R1 followed by a C also stamped into pistons.
Anyway, I've given up - for a number of reasons. If I rebuild this engine I'll go to 3.25 and be done with it.
