Re: Char-Lynn cooler
Posted by Vito on May 11, 2013 at 11:15:15 from (68.118.193.186):
In Reply to: Char-Lynn cooler posted by notjustair on May 11, 2013 at 09:23:16:
What are you running for fluid? Installation instructions says to use Automatic Transmission" A".
HTH
Vito
