Re: C leaking oil from brake shaft
Posted by Dennis K (WA) on May 11, 2013 at 17:37:54 from (24.21.78.195):
In Reply to: C leaking oil from brake shaft posted by whigg on May 11, 2013 at 15:20:48:
IH # 351108R91 which was replaced by IH # 70201C1.
SKF / CR replacement # 21336.
Bearing supplier, Napa or CaseIh should be able to help you out with these numbers. They are readily available.
good luck
Dennis
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
