Re: Won't spark
Posted by El Toro on May 12, 2013 at 05:02:03 from (108.3.218.181):
In Reply to: Won't spark posted by Backhoe Bob on May 11, 2013 at 18:40:57:
If you have battery ignition use a volt meter to check for voltage to your coil. With your switch in the on position and the points open you should have voltage on both small terminals on your coil.
No voltage here means either your switch is bad or you're not getting voltage to your switch. Use your volt meter or test lite. Hal
