Re: SMTA grill
Posted by redgems on May 12, 2013 at 06:58:08 from (204.14.163.20):
In Reply to: SMTA grill posted by mkirsch on May 11, 2013 at 19:39:58:
Steve Hendersun said: (quoted from post at 04:38:55 05/12/13) I thought that's what the two smaller holes were for? There is nothing behind the two larger holes.
There is a cast bracket that bolts to upper bolster .Its the backing to those big holes where everything mounts to.
If you look hard you can see bracket and threads in holes on the 400. The smta uses the same bracket. Holes would look simuliar.
Hope this helps, Tony third party image
This post was edited by redgems at 07:01:00 05/12/13 2 times.
