Assuming it has the band type IPTO,and the lever is not bent or linkage out of spec and no loose connections or worn Keys in the link pivot. There is a mark on the lever base (manual) that is midway from locked on, to locked off with the button on the handle. If you cannot find the marks, measure the lever travel and put it at 1/2 way. In this position, adjust the bands (seperately) (under the little peanut shaped cover on the top) until each is tight enough to prevent rotating the shaft by hand with a channel lock pliers. Then loosen each about one half turn. This will (should) make it free to turn by hand. It should also make it drive, and brake correctly. Make sure you click the lever latch in either position. Running it W/O latching will cause slipping. Linkage slipping, and bent rods are also issues to watch for. Good luck. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
