Re: Paint Fade.
Posted by CNKS on May 12, 2013 at 11:44:41 from (216.144.104.128):
In Reply to: Paint Fade. posted by Kevin B from Illinois on May 12, 2013 at 10:11:47:
If you wax cast you will remove more of the paint due to rather poor coverage of the "peaks" in the cast. If you put clear on it, it needs to be sanded first to make the clear adhere which will also remove paint. In other words it either needs to be repainted correctly or left alone. Red doesn't fade if you use quality paint, but you probably don't want to spend much money on a lawn ornament. Perhaps you can wax the sheet metal and leave the cast alone.
