Re: Paint Fade.
Posted by Kevin B from Illinois on May 12, 2013 at 11:50:40 from (173.20.194.215):
In Reply to: Re: Paint Fade. posted by Janicholson on May 12, 2013 at 10:40:40:
It would not be a lot of work I don't think but the motor is stuck, and I really don't want to crank start a tractor anymore but I did seal everything up as good as possible to keep water out dumped oil down the the spark plug holes the only bad part is I put extra oil in the oil pan but when sand blasting the pan is thin and oil came out so had to remove it.
