How to set the rear wheel for plowing with the C
Posted by SDE on May 12, 2013 at 18:39:40 from (174.124.52.124):
Is there a way to measure and set the right rear tire before actually plowing with the tractor? The tractor is a Farmall C and the plow is a Massey Harris 2-14. I know I will need to make a few adjustments to get it to plow correctly, but I would like to move the tire to the correct position before I head out to the field. The rear tires are new and I have two weights on the right rear and one on the left. Will that be enough? I want to enjoy this as much as possible.
Thank you
SDE
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
