Re: SC starter ring-gear replacement
Posted by mkirsch on May 13, 2013 at 05:38:11 from (216.43.0.134):
In Reply to: SC starter ring-gear replacement posted by BoonvilleKid on May 12, 2013 at 23:01:17:
What do you mean "slams?" That's how starters work. After 60 years of starting, the ring gears generally do show some wear. Perfectly normal. Replace it and it will last another 60 years.
Tractor needs to be split, and the flywheel removed, to replace the ring gear.
The old ring gear is cut off with a cutting torch. The new ring gear is heated, either with a torch or in an oven, so it expands enough to slide over the flywheel.
Unfortunately there is no book that will show you "exactly" how to do this yourself. Back when this tractor was new, the dealer mechanics did most of the major work, and they had training.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
