Re: New Hydrulic Couplings for 706
Posted by mkirsch on May 13, 2013 at 07:30:14 from (216.43.0.134):
In Reply to: New Hydrulic Couplings for 706 posted by Cmore on May 13, 2013 at 06:30:11:
Are you trying to hook them up under pressure?
Before you disconnect the implement, engage the transport lock, lower the implement to the ground, or block the implement up, then put the hydraulic lever in the "float" position.
Having the implement hoses under pressure makes them difficult if not impossible to connect.
If you still feel the need to replace, there is nothing special about the couplers. They are standard "Pioneer" type female couplers with a 3/4" O-ring thread. Take one with you to buy replacements.
