Only other thing you have to take into consideration is if you have a double acting check valve on that tractor. It may have. Easy to find out if you don't know what to look for. With implement raised, shut off engine. If you cannot lower the implement it has check valve. If it does, you need to convert to iso male and female couplings that can be hooked up under pressure. The check valves intent is to keep load from drifting down as all spool valves leak some even new and get worse as they get older.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
