Just jack it up and see if it turn ok then. If so, you can forget spindles and thrust bearings. May be as simple as the o-ring on the power steering relief valve or valve it self. Just pull bottom rear plug on mcv and if o-ring is shot the relief valve will fall out. If not, run starter a few seconds and blow it out. Easy to see if adjusting screw has unscrewed or valve is leaking. What is your red light doing when you steer. Should not come one, of course it has to be working like comes on when switch on, not running.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
