could be a couple of things from what you describe,are your hoses long enough to switch them from the bucket side to the loader side of the valves,if so change them and see if the problem moves to the bucket if so check the valve spool for proper travel,if travel is correct the valve could have internal damage which is uncommon,if switching valves has the same results as before then one or both lift cylinders is leaking internally a common problem,most of the time it is piston sealing rings damaged or worn out,but pistons will crack,cylinders will score ect. neighbor had the valves repaired on his mf industrial tractor it done the same thing yours is doing,the shop that built the loader spool up didn't machine the end groove back to it's original size was the problem
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
