Re: BN Starting Problems
Posted by old on May 13, 2013 at 19:38:13 from (209.86.226.61):
In Reply to: BN Starting Problems posted by jeffred on May 13, 2013 at 19:28:08:
As with any engine you check spark and make sure it is a good blue/white and will jump a 1/4 inch gap. Then you check fuel flow by pulling the carb drain plug and let it flow a few minutes. Catch it so as to look for water and dirt etc. Also make sure you air cleaner is not stopped up or full of water
