Posted by rustyfarmall on May 14, 2013 at 07:15:16 from (216.248.71.226):
In Reply to: H carb kits posted by BigDanT on May 13, 2013 at 17:25:36:
Did you remove the fuel inlet fitting? There is a very fine mesh filter screen attached to that fitting. If it is dirty and clogged, it will cause the problems you describe. That screen can easily be cleaned with some aerosol carb cleaner and compressed air. I seriously doubt you will need a complete kit. A new gasket, possibly a float valve and seat, and adjusting the float should change the attitude of that H.
You really do not need to be concerned with the carb number or model. The pieces you will need are the exact same for all of H carburetors.
If you can work on a Ford, You can work on a Farmall.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
