Re: B vs BN
Posted by TexasCC on May 14, 2013 at 09:16:55 from (24.227.240.164):
In Reply to: B vs BN posted by TexasCC on May 14, 2013 at 05:34:10:
Thanks again for all the help, and the pictures were great! One more thing, if I may ask, I have both the stamped steel wheel center and also the heavy cast wheel center. Does the heavy cast center go on the right side of the tractor and the stamped on the left, or do both cast centers go on the same tractor.
