Re: Farmall A conversion
Posted by Janicholson on May 14, 2013 at 17:54:35 from (74.60.94.18):
In Reply to: Re: Farmall A conversion posted by WV Farmall on May 14, 2013 at 16:58:36:
third party image
This is correct. The pressure switch is from napa and has 1/8" pipe threads (closed at about 5 psi, and open with no pressure. "T" it into the oil pressure connection. The mag cannot have any power to it it is grounded at the side terminal to make the tractor stop. If power was put to it it may nave at least burnt points if not toasted mag coil. The on off switch is a grounding kill switch.
